Re: 300 utility hydraulics
Posted by big fred on November 13, 2010 at 23:50:16 from (97.113.177.134):
In Reply to: 300 utility hydraulics posted by DSW on November 13, 2010 at 15:20:38:
Try putting some pressure to that breather port when the engine is running. The 300U system needs to have the line to the pump primed if the fluid level drops too low. You may have lost prime. It only takes about 5 psi and takes maybe 5-10 seconds. When the pump primes you will hear a change in engine sound while it brings the system up to pressure. If it doesn't prime in a minute or so, then it's time to take the reservoir cover off and check the screen. I used a engine hoist to remove the cover on my 300U. It isn't all that heavy (maybe 40-60 lb?), but it's awkward, and you don't want to set it down on a flat surface as you'll crush the screen.
