Re: A oil pressure
Posted by Tom Fleming on November 14, 2010 at 02:41:38 from (206.193.253.243):
In Reply to: A oil pressure posted by bkpigs on November 13, 2010 at 15:23:17:
Oil pump face plate is leaking is my guess (as others have stated). Actually a relatively easy fix, but you will have to drop the pan again and remove the oil pump to do it right (although, you could do it with the pump in also). CIH still has the gaskets.
As a bit of good natured advice to you and other that may read this post, if you have gone to the trouble of dropping the pan and replaced the bearings, you should do the oil pump while you are in that far. Not a slap, but a suggestion.
IMHO.
