Re: search function failing me super A suffix numbers
Posted by outlar on November 14, 2010 at 08:32:39 from (74.198.8.57):
In Reply to: search function failing me super A suffix numbers posted by CenTex Farmall on November 09, 2010 at 06:53:45:
My chassis serial number and the engine block serial does not have the FAA designate prefixed to the 6 number serial number, Is this common and what does it mean not to have the numbers listed this way.
