Yes the choke needing to be wide open is a red flag as far as the carb goes and does indicate that the carb needs to be cleaned. However, I have never seen a "gummed up" carb that caused the tractor to run wide open. I think there must be better gasoline in my area, as I have left gas in carbs for a year and have not had trouble starting them (I don't recommend that). I mentioned the governor because your wide open symptoms were the same as when I bought my 460, other than the choke.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
