Re: The great Super C vs Straight H debate...
Posted by tempola on November 18, 2010 at 04:50:46 from (69.29.212.105):
In Reply to: The great Super C vs Straight H debate... posted by Pete76NY on November 17, 2010 at 21:53:19:
I have owned and worked both tractors, and Pete is right.
how many Super C's have you seen rear up on the pulling track, and how many H's just run out of power and stall? Ive seen that happen often!
the regular H is a good old tractor, but underpowered, and a super c can give it a run for its money. It's called horsepower to weight ratio guys. a overbore kit, or even better, a super H engine with a overbore kit. THEN a super c cant touch it.
Ill keep My super c with fast hitch.
