Re: The great Super C vs Straight H debate...
Posted by Stuart on November 18, 2010 at 06:20:50 from (64.198.86.189):
In Reply to: Re: The great Super C vs Straight H debate... posted by tempola on November 18, 2010 at 04:50:46:
A C never had enough power to rear up, just light enough to spin out. Hp to weight ratio doesnt mean a thing plowing or pulling. I have a JD 60 with 43 hp and I can out plow tractors with 55 hp and out pull them if I get enought weight on it. I wiegh in stock at 6200 lbs at 43 hp you might consider it a dog, but its not,it never runs out of power, even in the 10,000lb class. Maybe as a puller a c is better but not on the farm.
