Re: farmall tach drive distributor?
Posted by Wardner on November 21, 2010 at 21:09:43 from (4.154.233.118):
In Reply to: farmall tach drive distributor? posted by tempola on November 21, 2010 at 20:33:09:
IH began with tachs in 1955. Any four cylinder IH engine from that date until 1958 that has the tach drive hole and 2-screw cover can use any of the three tach drives. IH Gas or Diesel use the same drive. They are interchangeable. Later models of the Cub and 140 also use the same drive.
You need a gas tach. The Diesels rotate backwards. You want a 0-2400 IH tach with the "0" on the left hand side. They will all work but the road speed numbers will be slightly off. The 540 RPM line will vary also.
Tachs are being reproduced and they are a quality item. You can find them new on eBay between $60 and $130.
I don't believe there is a source for new tach drives. Used drives (usually as part of the distributer drive) can be had on eBay for around $50-$100. You take your chances on a used drive. The gear is plastic and may be stripped. eBay buyer protection plan will refund your cost if the drive is no good.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
