farmall tach drive distributor?
Posted by tempola on November 21, 2010 at 20:33:09 from (72.161.235.90):
I posted this in the tractor pull fourms with no replies so I will try it here
I think I have a place for tachometer drive on my uc-135 engine, its on the lower housing behind the distributor. a small plate with two screws.
what part # or tractor model am I looking for to get the proper gear and housing? what type of mechanical tach should I use?
will post pics later today.
thanks in advance
Andy
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
