Re: M carb float issues
Posted by Hendrik on November 22, 2010 at 01:02:55 from (194.53.253.51):
In Reply to: Re: M carb float issues posted by Dick Binfield on November 21, 2010 at 19:39:27:
... and sometimes the leak is between the seat and the carb body.
You may use method in the link shown to trace your carb problem.
HTH, Hendrik
