Re: M carb float issues
Posted by Dick Binfield on November 21, 2010 at 19:39:27 from (96.31.184.82):
In Reply to: Re: M carb float issues posted by Dave H (MI) on November 21, 2010 at 18:53:43:
I did install a new needle and seat.I used carb cleaner and blew it out with air and pressurized kennesol(like brake cleaner). I will check the seat orifice and blow it out again.
Thanks
