Posted by Dave H (MI) on November 22, 2010 at 07:09:08 from (64.12.116.73):
In Reply to: Re: M carb float issues posted by Dick Binfield on November 21, 2010 at 19:39:27:
I'll tell you something and do what you will. If the float has no fluid in it when you pull it out and emits no bubbles when immersed in hot water then the seat is your likely candidate. If you replaced a solid needle with one of the neoprene tipped ones try putting the old one back in and see if it stops leaking. Once you get it to stop leaking there are cheap gravity flow filters that you can use along with a rubber gas line to check to see if a lot of crud is getting in the system from somewhere. Run it that way for a month or so and then put your regular line back on if it is running good and the filter does not block up. You can't just kit out a carb on what is basically an industrial machine that spent decades in the dirtiest outdoor environment imaginable. You have to work from the tank down and clean it all.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
