I suggest you concentrate on getting the Zenith working correctly as parts are available for it and you won't be able to find everything most likely for the Carter UT which you probably have. I have never been happier since I threw the original Carter away and put on a new Zenith on my Super C as my carb problems are a thing of the past, Hal.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
