Carter Carb on 100 woes
Posted by couv on November 24, 2010 at 05:18:50 from (209.33.29.72):
If I remembr correctly, Pa-In-Law took this Carter off the 200 because it didn"t run "right".
With my Zenith carb developing problems, I cleaned the Carter well, took out every jet, sprayed cleaner in every passasge & blew air through every passage, then put it on.
At mid-point on the throttle quadrant, motor seems to be running at about 1/3rd rpm (not idling). At one notch below that midpoint, it dies quickly - no sputtering, just rrrrrrrrrstop.
At full open on quadrant, engine seems to be about 3/4 wide open.
