Re: Carter Carb on 100 woes
Posted by rustyfarmall on November 24, 2010 at 12:02:14 from (209.152.78.140):
In Reply to: Carter Carb on 100 woes posted by Leroy on November 24, 2010 at 05:18:50:
The Zenith might need a new float, but most likelt it just needs the float valve and seat cleaned up and put right back in. Probably need a new gasket also as the gasket will most likely not come off without destroying it. Maybe a 20 minute job for experienced folks, maybe an hour for inexperienced.
