Re: Converting 6v to 12v - Simplified?
Posted by jdemaris on November 25, 2010 at 07:26:38 from (72.171.0.141):
In Reply to: Converting 6v to 12v - Simplified? posted by Dellbertt on November 25, 2010 at 06:12:05:
If such a converter/voltage increaser exists - still makes little sense to me.
If you've got an original 6 volt generator, it's likely to have a 12 amp max output. Convert it to make 14 volts and it will barely make 6-7 amps running fast, and maybe 1 amp at lower speeds - IF you're lucky. Just enough to keep a battery charged and little else.
Stick a $25 Delco 10SI alternator on there with the correct pulley-ratio and get 23 amps with the engine idling, and 63 amps full output. Plenty of power for accessories, headlights, etc.
Considering the alternator is much more durable, does not use brushes to carry current, parts available anywhere, seems the end-result IS simplicity.
I can understand keeping the OEM generator if looks ARE important- but that's not what you posted about.
