Re: Converting 6v to 12v - Simplified?
Posted by greyfoxxca on November 25, 2010 at 09:43:41 from (137.186.159.24):
In Reply to: Converting 6v to 12v - Simplified? posted by Dellbertt on November 25, 2010 at 06:12:05:
P = I x E
power is equal to amps times voltage
your tractor power needs stay the same
your voltage doubles
your current in the generator is half
the 6 volt generator will run at half the current flow at 12 volts. I would say if the power does not change the alternator would be cooler. If you increased the power needs this would change.
from answers.com
Ohm"s Law defines the relationships between voltage (E), current of charged particles (I), resistance (R) and power (P). One ohm is the resistance value through which one volt will maintain a current of one ampere. One volt of voltage moving one ampere of current is "creating" one watt of power (the so-called volt-amp).
( I ) Charged particles (usually electrons) are what flows in a wire or conductor like water flowing through a pipe. Electrons flow through a conductor from points in a circuit that are more negative to points in that circuit that are more positive (electron current, also called electron flow). This flow, or current, is measured in amperes (A).
( E ) Voltage is the difference in electrical potential between two points in a circuit. It"s the push or (electrical) pressure that moves electrons through a circuit. It is what causes current flow, and it is measured in volts (V).
( R ) Resistance is a measure of a material"s opposition to current flow. It determines how much current will flow through a component for a given voltage. Resistors are used to control voltage and current levels. A very high resistance allows a small amount of current to flow for a given voltage. A very low resistance allows a large amount of current to flow for that same voltage. Resistance is measured in ohms (upper case omega).
( P ) Power is the amount "work" being done in a circuit. It is current times the voltage level across a given portion of the circuit, and it is measured in watts (W).
Here"s how it works:
E = I x R (voltage equals current times resistance)
P = I x E (power equals current times voltage)
There are variations on the theme, and here are all the expressions of Ohm"s law:
E = I x R or Voltage = current times resistance
I = E / R or current = voltage divided by resistance
R = E / I or resistance = voltage divided by current
P = I x E or Power = current times voltage
P = I2 x R or power equals current squared times resistance
P = E2 / R or power equals voltage squared divided by resistance
