340 Utility Electrical ?
Posted by Fallon on November 25, 2010 at 10:57:21 from (75.106.194.183):
Just picked up what I believe is a 1958 340 utility. No serial # or emblems. It has a key switch and also a starter button. At sometime the key switch was jumped across and the negative wire leading from the coil taken off of the place it is suppose to go to. When I hook the 6 volt battery up it turns over but will not stop turning over until battery is disconnected. It does not fire off. Would like to know where the coil wire should go to and how to fix the key start problem and starter button issue. Any help would be great. Thanks
