Re: Converting 6v to 12v - Simplified?
Posted by gbs on November 25, 2010 at 15:52:05 from (71.0.23.110):
In Reply to: Converting 6v to 12v - Simplified? posted by Dellbertt on November 25, 2010 at 06:12:05:
I have a question about the voltage carrying capacity of wire that seems to come into discussion a lot concerning generators,i work on high voltage lines for a living ,don't quite understand some of the theories, voltage has little to do with wire size it the amperage load that determines that case in point 30 amps at 7 kv uses the same wire as 44 kv the higher volt enables longer transmission distances without so much voltage drop
