Posted by Owen Aaland on November 25, 2010 at 22:14:45 from (65.165.246.145):
In Reply to: 706 Reverse problem posted by kennell on November 25, 2010 at 19:34:02:
If it shifts into high range and low range like it should then most likely the problem is under the cover and not linkage adjustment.
Likely causes are a broken/missing roller on the reverse arm or too much play where the arm pivots in the cover. Less likely causes are a broken reverse shift fork or broken thrust washers on the reverse idler shaft.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
