Re: bn will not start
Posted by old on November 26, 2010 at 10:11:11 from (4.245.11.215):
In Reply to: Re: bn will not start posted by TODD HECK on November 26, 2010 at 10:04:49:
Not sure what causes them to brake but have seen more then one. Also common for them to hang up in the ring gear but that most of the time locks them up but can also act like what your is doing. Can you turn it over by hand?? If you can not then pull the starter and if it is ok put it back on and try it you may find it will then start if the starter has not broken
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
