Re: foxxy...
Posted by WSJ on November 26, 2010 at 17:06:00 from (216.139.17.182):
In Reply to: Converting 6v to 12v - Simplified? posted by El Toro on November 25, 2010 at 06:12:05:
The average field coil voltage on my Farmall H was measured at 7 Volts, battery 14 Volts and battery 14 amps using a 6 Volt generator and the Bosch solid state regulator. Under these conditions the field coil temperature would be the same as in a 6 Volt charging system.
The average field coil voltage was 7 Volts because the regulator was operating at a 50% duty cycle, which means the coil voltage was being switched on 50% of the time and off 50% of the time. Both mechanical and solid state generator and alternator regulators use Pulse-Width-Modulation (PWM) to control the charging system output.
The following site explains Pulse-Width-Modulation.
http://www.netrino.com/Embedded-Systems/How-To/PWM-Pulse-Width-Modulation
Wayne
third party image
