I wouldn't think the mag would have anything to do with a battery drain since a mag isn't powered by the battery. Instead I would probably go for the voltage regulator. Connect a test light in series between a battery cable and the battery post. If the test light lights up, then you have a drain. If not, then you probably have a battery with an internal drain. If you have a lit test light, then start disconnecting wires, one at a time. When you disconnect the circuit with the drain the light will go out. I would probably start with the wires to the VR. The VR contacts can stick, causing a drain. Hope this helps.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
