Posted by Moondoggie on November 26, 2010 at 20:28:09 from (66.187.36.48):
My '49 Cub has 2 problems. First, with the magneto start switch 'off' or 'on' there is a drain on the battery, enough to wear it down completely. Is there a spot I should look at for the drain? Second, the oil pressure stays high - to the far right of the gauge. Took the spring out of the oil pressure relief valve, but the valve is stuck. Any suggestions to get it out? Thank you. Hope your Thanksgiving was quiet and fattening.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
