Manifold Condensation
Posted by redgems on November 27, 2010 at 01:18:26 from (108.112.178.78):
Hi Fellas, I have f-400 gas with a 450 three rib manifold. Having tremendous amount of condensation on carberator updraft. Water forms outside of updraft and runs down carb and drips. there are two little drain holes on lower inside two exhaust manifold ,wondering if heat escaping from these hitting carb is causing this problem and wonder if plugging them would help.tractor runs fine but water is discoloring & rusting outside of carberater. Thanks for suggestion, Tony
