Re: Manifold Condensation
Posted by D Slater on November 27, 2010 at 05:54:02 from (184.15.11.88):
In Reply to: Manifold Condensation posted by redgems on November 27, 2010 at 01:18:26:
Thats kind of normal in some climates this time of year. If you always park inside or cover the exhaust it won't hurt to plug the drain holes in the manifold. IH sold a block to clamp on 400 pre 3 rim manifolds for more heat transfer to intake for use in some climates to help with ice forming in and on the intake.
