Re: '49 Cub: Battery drain and high oil pressure
Posted by gene bender on November 27, 2010 at 03:29:29 from (67.55.227.196):
In Reply to: '49 Cub: Battery drain and high oil pressure posted by Moondoggie on November 26, 2010 at 20:28:09:
off on sw has nothing to do with that problem as it is just a grounded sw to kill the mag. Your voltage reg or cut-out must be sticking to drain the batt ar further yet are you sure your battery isnt at fault. When you slow the engine speed and then stop the engine the ammeter should deflect some to O.
