Re: Re: Re: Re: Re: Re: RADIATOR DRAIN LINE
Posted by Kenneth Harris on June 30, 2000 at 03:11:09 from (207.230.55.58):
In Reply to: Re: Re: Re: Re: Re: RADIATOR DRAIN LINE posted by The Red on June 28, 2000 at 11:31:25:
On my 1957 450 Farmall the drain pipe was about seven inchs long, if you do decide to pull the radiator you will either have to cut the bottom of the fan shroud out to clear the fan blade or take it off (four 5 inch bolts held mine on and the'll more than likely be rusted) the reason I say this is because you'll have to pull radiator stright up out of the hole with the pipe and I hope someone didn't install a larger than the hole drain cap because if they did and you can't remove it your in trouble. On mine I can remove the bottom radiator hose and the drain pipe is exposed right there inside, squirt it with WD-40 or some other corrosion remover and think positive. Ken Harris
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: RADIATOR DRAIN LINE
