Re: More questions on 39 M
Posted by Bob M on December 02, 2010 at 06:08:42 from (67.240.171.41):
In Reply to: More questions on 39 M posted by Baelee05 on December 02, 2010 at 05:19:42:
A cutout generally has only 2 wiring terminals. A VR will have 4 terminals.
Also a cutout is usually a small, rectangular "can". OTOH a VR enclosure will be about 3" square.
Cutouts are almost always mounted atop the generator. If the original cutout was replaced with VR, the VR might also be mounted atop the generator. But it could also be mounted almost anywhere else between the generator and the ammeter box depending on the whim of the owner.
The throttle response problem sounds like a sticky or misaligned governor to carb linkage tube.
First loosen (but don't remove) the 2 screws that clamp both end of the gov to carb tube. Now with the governor handle set all the way forward (idle), wiggle both ends of the tube up and down. Then retighten the clamp screws.
If that doesn't fix it, you'll need to remove the carb and gov to carb linkage and check for sticking/binding parts.
