More questions on 39 M
Posted by Baelee05 on December 02, 2010 at 05:19:42 from (12.192.13.220):
As I understand it the 39 M is supposed to have a cut out relay instead of a regulator. How do I tell the difference between the two? After looking again I might have a cut out relay. Where should the cut out relay be mounted on the 39 M? Is there any way to check and see if it is any good?
I also need to check over the magneto on this tractor. I assume that this would be the H4 magneto? How do I make sure I don't get knocked on my tail while working on this thing? I have heard of guys getting nailed by them. I have never worked on a mag. Serviced many a distributor. Is it more or less the same kind of deal working on a mag?
One other thing. The repsonse from the governor seems to be very erratic. It seems like you have to move the throttle lever quite a ways before you get any repsonse and when you do you get a response it is sometimes more than you wanted. Same with throttling it down. Took the cover off of the governor and everything in there appears to be well lubed and the spring is not broken. Any suggestions?
