Re: foxxy...
Posted by WSJ on December 02, 2010 at 21:21:02 from (216.139.17.182):
In Reply to: Converting 6v to 12v - Simplified? posted by John T on November 25, 2010 at 06:12:05:
Dell,
A low compression low RPM engine is the least demanding on coil performance. Any reliable 12 Volt coil designed to operate without a ballast resistor should be fine.
Order this coil with the Bosch solid regulator and pay only one shipping charge.
This Genuine Bosch Blue coil is an Epoxy filled coil with a steel casing. The epoxy filled coil can be mounted in any position and will not leak oil (because there is no oil). $40
http://www2.cip1.com/ProductDetails.asp?ProductCode=BOS%2D00012
Wayne
