How to Check a Coil?
Posted by Doug Kieta on December 03, 2010 at 11:19:55 from (99.27.148.106):
My 51H has started to die after starting easily and running well. At first I suspected a plugged fuel line, but after completely disassembling and blowing out the fuel system, I am beginning to suspect that my coil is heating up and creating an open circuit. As soon as the engine sets for a few minutes, it starts again, and again stops after a brief run.
How do you check a coil to see if it is bad?
Any other diagnostic suggestions?
As usual, thanks for the help!
