Re: How to Check a Coil?
Posted by old on December 03, 2010 at 13:19:14 from (4.245.13.66):
In Reply to: How to Check a Coil? posted by Doug Kieta on December 03, 2010 at 11:19:55:
That one is so simple even a cave man can do it. Start the engine. Run it till it dies. As soon as it dies check for spark. If you have no spark you either have a bad switch or bad coil or maybe but not likely a bad condenser. To check the switch you hot wore it. Doing it that way works as good as 90% of any bench tests a home hobby guy can do
