Answer is "it depends". Best case scenario is a battery charge (free) and perhaps a new voltage regulator ($40).
More likely however you will also need a new 6 volt battery, voltage regulator and new heavier, battery cables - about $150 or so.
And if the generator is bad, a rebuild will run another $100 - $125.
Incidentally I would replace the existing 8 volt battery with a new 6 volt regardless. Over the long haul it will cost less to find/fix the problem that caused the previous owner to install an 8 volt battery in the first place!
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
