Looked at tractor today...generator problems. Expensive??
Posted by RTR on December 05, 2010 at 18:55:39 from (74.248.177.174):
I went and looked at a Farmall Super A with the 6 volt generator (picking it up tomorrow actually). It had the voltage regulator (square box) mounted on top of it. When I started the tractor it seemed like it barely had enough power to start it, and if the tractor didn't run so well, it wouldn't have. There is an 8 volt battery (which I would think would have more power than a 6 volt battery), and it just seemed WAAAY too weak to me. While it was running, the ammeter read on the negative (left) side, and read around the -10 mark on the left side.
Otherwise the tractor has been "restored" and is flawless otherwise. A local guy that specializes in Farmall offset tractors has it. What am I getting into, and how much will it cost to fix approximately. THANKS.
