Farmall C not cooling?
Posted by Faster346 on December 06, 2010 at 12:42:52 from (72.241.213.69):
I don't think my Farmall C is cooling. I just got done with the restoration on it, and put it back together, put the radiator on, put a 50/50 mix of green Antifreeze and Hose Water into it, about a inch full from the top, and have let it run for about 20 minutes a couple times. The upper radiator hose and top of the radiator get hot to touch, but the lower hose, and bottom of the radiator stays ice cold. Someone told me the lower hose should be warm, and the top should be hot, but to put your hand on the radiator fins, the top is hot to touch and the bottom fins towards the bottom are ice cold. Is this not normal? How do I fix it?
