Posted by Janicholson on December 06, 2010 at 20:38:52 from (67.72.98.45):
In Reply to: Super C problems posted by Idaho Ron on December 06, 2010 at 17:53:30:
Handyman info on the voltage is correct only if the tractor stopped with the points open (very unlikely, they almost always stop with them closed as the last cylinder on compression pushes the engine back to about 1/2 stroke. If you test the coil vor voltage with the points closed, it will only have voltage on the switch side, the wire to the points will be the same as ground (because it is grounded through the points. To test it one must open the points and put a slip of plastic or cardboard between them. Then voltage will be at both terminals of the coil.
Point setting is .020" when the distributor cam is directly on one of the 4 lobes. THe tractor must be turned by hand (fan or hand crank, or pushing in high gear) to get it to that position. Good luck. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
