Re: Cracked block! Repair or replace?
Posted by El Toro on December 08, 2010 at 16:08:21 from (108.3.200.96):
In Reply to: Cracked block! Repair or replace? posted by 1468 Chris on December 08, 2010 at 15:53:31:
I would replace the block with a good used one.
Someone on the Farmall forum may have a parts tractor with a good block. I would place a request over there. Use the Advanced Posting Tools for posting your pictures. You need your pictures stored on your computer like "My Documents" as APT will take you there automatically. Click on "Upload Photo", then on "Browse" then select your picture, then click on "save" then on "upload" when your picture appears in the "window" click on "Continue".
Then click on "Preview Your Reply" and see if your pic appears with your message. Hal
