Cracked block! Repair or replace?
Posted by 1468 Chris on December 08, 2010 at 15:53:31 from (199.246.2.11):
I just got the sleeves outta my little farmall A and cleaned the block all up and found that it is cracked between all of the cylinders. Ive rebuilt a fair number of motors but have never got one with a a crack. Do you guys think that this block is repairable or should i start lookin for a replacement? Its a 1939 A without a water pump. I don't know how to post pictures or i would show you. Thanks in advance
