If your block is cracked in All cyl. that block is done. You can use a block from an A or B farmall up 1946 as they are the same even newer on an A or Super A as long as no H2O pump on newer block. If your going to restore the tractor do it right you will not be sorry. This is only one mans opinion I hope it helps. Doug
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
