Re: Cracked block! Repair or replace?
Posted by gene bender on December 08, 2010 at 16:42:18 from (67.55.227.196):
In Reply to: Cracked block! Repair or replace? posted by 1468 Chris on December 08, 2010 at 15:53:31:
Theres on for sale just look at implement parts on the photo adds on this site 417-669-8511 or you can send it to Williams in Nevada,Iowa and they can weld it. If its cracked between the cycls i would get another block. I dont have any more rite now or i would sell you one. They go for around 200 or more as they arent making any new one been a long time since production ended in 47. You can replace with one from a C or SC and block off the hy pump space. You can also get one from a baler or a combine. They had the starter mounted forward below the filter but they will work on a tractor. I do have one of those. I also have an A with one of those engines and they work just fine
