Got the engine rebuilt but the thermostat housing leaks!
Posted by Yooper Farmall on December 09, 2010 at 09:13:38 from (141.210.112.16):
So finally got my "41 H engine rebuilt with new valves and high compression pistons. Reattached the manifold and carb, pressed the starter button, it turned over for about 2 seconds and fired right up!
We had a pretty big leak around the thermostat housing even though I put in a new gasket, a little extra gasket material fixed it, but now there is a little bit of fluid dribbling from the heads of the two 3.5" bolts that holds the two sections of the housing together. Is there supposed to be brass or copper washers or something to seal this up??
