Re: Cracked block! Repair or replace?
Posted by 1468 Chris on December 09, 2010 at 11:23:28 from (199.246.2.11):
In Reply to: Re: Cracked block! Repair or replace? posted by rustred on December 09, 2010 at 06:42:02:
Rustred what is Devcon? Ive never heard of it? How does it work? Have you used it? The cracks are right on top of the block and there is 3 cracks, But they go into the webbing right below the deck. The cracks appear to be right were the block was put together. Id like to keep this block if possible.
