Re: Cracked block! Repair or replace?
Posted by rustred on December 09, 2010 at 12:09:32 from (74.200.18.155):
In Reply to: Re: Cracked block! Repair or replace? posted by 1468 Chris on December 09, 2010 at 11:23:28:
devcon is a better form of J B weld . it is like a paste. yes i have used it with good results. i did the very similar same thing as you have there. thats why i say to use it and then plane the head.should be able to v out the cracks with a dremel tool.on my block got it warmed up good then give it the devcon treatment and then wrapped it in insulation to cool slowly . dont know if this was nesessary but it worked and is still going after 14 years.
