Re: Engine surging, govenor adjustments
Posted by wayne in mn on December 09, 2010 at 11:44:04 from (66.228.242.147):
In Reply to: Engine surging, govenor adjustments posted by Yooper Farmall on December 09, 2010 at 10:23:35:
Try adjusting the carburetor first.
1. have engine at normal operating temp(cover radiator)
2. pull throttle lever ALL the way back for maximum engine speed
3. turn high speed(bottom) mixture screw out(richer) or in(leaner) until engine runs at maximum speed(smoothest sound)
4. turn high speed mixture screw out an additional ½ turn for slightly more fuel for maximum power
5. with engine idling, re-set idle air mixture & idle rpm screws
If this doesn't cure your problem, check timing and lastly the governor.
