Posted by Yooper Farmall on December 09, 2010 at 10:23:35 from (141.210.112.16):
As previously mentioned I recently rebuilt my H engine, the compression had been very low, the valves visibly worn, the rings flopped around in the piston grooves and it had very little power. It now starts easier and runs smoothly at a low idle but I still have one recurring problem, the engine surges back and forth at higher speeds as if the govenor is searching back and forth and tring to catch a moving target. I had already replaced the govenor spring, what should I check next? From previous posts I know to check for slop in the linkage between the govenor and carb, what else? Thanks in advance.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
