Re: Engine surging, govenor adjustments
Posted by rustyfarmall on December 09, 2010 at 12:00:22 from (209.152.78.140):
In Reply to: Engine surging, govenor adjustments posted by Stuart on December 09, 2010 at 10:23:35:
I think you are dealing with a worn out governor. The pins that the weights pivot on are worn, as well as the holes in the weights where the pin fits. Could also be some wear that prevents the fly-weight assembly from moving freely. It can all be fixed. The best way is to buy a governor kit if you can find one, but you won't like the price. Another option is to find a governor that is in better condition, but you won't know if it is better until you install it. I guess option 3 is to remove the governor from the tractor, set it on the work bench and take it all apart, find the badly worn areas and figure out how to fix it. 1/4" shoulder bolts of the proper length CAN replace those worn pins, but you'll need to drill out the holes in the weights a tad so they'll fit. With enough determination, you can get rid of most of that surging, but to get it to operate perfectly might be another story.
