Re: (Jim) Firing Voltage versus Compression
Posted by John T on December 12, 2010 at 18:07:23 from (66.244.97.31):
In Reply to: Re: (Jim) Firing Voltage versus Compression posted by agpilot on December 12, 2010 at 17:45:36:
Yep thats how I always understood it although I cant explain the physics of why. It seems somehow with more molecules packed in there in the space (higher PSI denser air) between the plugs electrode and ground strap theres more resistance to the striking of the arc across the crowed space, but if pressure decreases and especially if it were in a vacuum, it takes less voltage potential before the arc will occur.
The arc is ionizing the air molecules right??? Im still not sure how or why but Im confident it takes more voltage across the gap to arc current as the pressure increases.
Wheres a good physicist when we need him lol
John T
