Posted by Stuart on December 12, 2010 at 19:16:17 from (64.198.86.189):
In Reply to: Farmall H locked up! posted by Millercreek on December 12, 2010 at 18:52:47:
Pull all the drain plugs out. Rinse it out with diesel fuel to get all the water out. Use at least an 80w90 GL-5 or better. 85w140 will work to, better for gear life. Like with anything the better the oil you use the better off you are.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
