Posted by Millercreek on December 12, 2010 at 18:52:47 from (64.85.215.18):
Since it was 22 below windchill today my H was locked up in the rearend. I havent had this tractor but a few months and this is the first cold spell for it. I had to put a heater under it and thaw the transmission out to make it move. After it started it would die when i let the clutch out in neutral and I assume the gear oil has some water in it. or that's the only thing I can think. How do I go about draining all the oil and refilling with new. and what type of oil?
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
