Re: Farmall H locked up!
Posted by Janicholson on December 12, 2010 at 19:17:16 from (67.72.98.45):
In Reply to: Farmall H locked up! posted by Millercreek on December 12, 2010 at 18:52:47:
80-90 gear oil is correct. You can make a temporary fix by letting it sit (warm enough to be above freezing) and remove, to the near last thread, the two drain plugs only enough to let the water out, then rethread them. you will get a little oily, but it will stop the freezing till it is warmer. It might take 2 days to settle back out if it was used extensively when thawed. Jim
